ผู้เขียน หัวข้อ: Ion Exchange Resin Chemicals, Water Filter Resin Factory, Sales Water Treatment.  (อ่าน 1430 ครั้ง)
  • กระทู้: 3896
« เมื่อ: วันที่ 4 พฤษภาคม 2025, 01:45:09 น. »
Sales Water filter, Buy Ion Exchange Resin
Ion Exchange Resin Company, Sales Ion Exchange Resin,
Water Filter Resin Factory, Water Filter Resin Production
Water Filter, Ion Exchange Resin, Ion Exchange Resin, Ion Exchange Resin, Water Filter Resin, Water Filter Resin Ion Exchange Resin, Ion Exchange Resin, Ion Exchange Resin Anion Exchange Resin, Anion Exchange Resin Cation Exchange Resin, Cation Exchange Resin Mixed Ion Exchange Resin, Mixed Ion Exchange Resin
Alum production, Alum distribution, Alum import, Alum export,
Alum factory, Thai alum, Industrial alum Production of cloudy alum,
Distribution of cloudy alum, Import cloudy alum, Export cloudy alum,
Cloudy alum factory, Thai cloudy alum Production of clear alum,
Distribution of clear alum, Import clear alum, Export clear alum,
Clear alum factory, Thai clear alum Production of alum powder,
Distribution of alum powder, Import alum powder, Export alum powder,
Alum powder factory, Thai alum powder Production of alum pellets,
Distribution of alum pellets, Import alum pellets, Export alum pellets,
Alum pellets factory, Thai alum pellets Production of alum lumps,
Distribution of alum lumps, Import alum lumps,
Export alum lumps, Alum lump factory,
Thai alum lumps Production of alum lump no. 1,
Distribution of alum lump no. 1, Import alum lump no. 1,
Export alum lump no. 1 Production of alum lump no. 2,
Distribution of alum lump no. 2, Import alum lump no. 2,
Export alum lump no. 2 Produce Alum Block No. 3,
Distribute Alum Block No. 3, Import Alum Block No. 3,
Export Alum Block No. 3, Produce Alum Water,
Distribute Alum Water, Import Alum Water,
Export Alum Water, Alum Water Factory, Thai Alum Wate
You can inquire about product information, request product samples and order products at
Thai Polychemical Co., Ltd. (Water Treatment Chemicals)
TPCC PKSN RESIN THAILAND
Ion exchange.
Remove metals
Resin filter
Resin filter is a substance that looks like yellow-orange fish eggs, which is suitable for filtering out hardness mixed with water. It is a substance that is very necessary for water filters when filtering tap water or groundwater. The main function of the water filter resin is to remove limestone and filter out the hardness of the water. This allows you to drink and use the water without fear of harm to the body. It also helps to make the water soft on the tongue and not rough on the throat.
What is a resin filter?
Resin filter is a polymer that cannot be dissolved in water. It will be in the form of small spheres like fish eggs with a diameter of about 1-2 millimeters and is yellow in color.
Each brand of resin filter will have a different color, but it is still a clear golden yellow.
The resin works by absorbing calcium and magnesium from the water that flows through the resin filter.
As the water flows through the resin, it will release sodium.
Resin filters are suitable for use in water filters for consumption.
What are the properties of resin filters?
1. Resin filters help filter out the hardness of water, allowing you to drink water without harshness.
2. Resin filters help remove limestone mixed in water, which is not good for the body and can have an adverse effect on the kidney system.
3. Resin filters help remove solutions in the form of ions, such as bicarbonate, all minerals mixed in pure water.
More information about Resin water filters (Ion Exchange Resin)
You can inquire about product information directly at Thai Polychemical Co., Ltd.
Currently distributed by Thai Polychemical Co., Ltd. are as follows
ACID (กรด)
Acetic Acid (กรดอาซีติก)
Boric Acid (กรดบอริก)
Citric Acid (กรดมะนาว)
Formic Acid (กรดฟอร์มิก)
Hydrochloric Acid (กรดเกลือ)
Nitric Acid (กรดไนตริก)
Phosphoric Acid (กรดฟอสฟอริก)
Sulphamic Acid (กรดซัลฟามิก)
Sulphuric Acid (กรดกำมะถัน)
BASE, SALT (เบส,เกลือ)
Diatomaceous Earth (ดินเบา)
Quick Lime (ปูนขาว, ปูนร้อน)
Soda Ash Dense (โซดาแอชเดนส์)
Soda Ash Light (โซดาแอชไลท์)
Sodium Borate (โซเดียมบอเรต)
ALUM (สารส้ม มอก.165-2554)
COAGULANT (สารเร่งตกตะกอน)
Biocide (ไบโอไซด์)
Chlorine 10% (คลอรีนน้ำ 10%)
Defoamer (สารลดฟอง)
EDTA 2Na (อีดีทีเอ 2 โซเดียม)
EDTA 4Na (อีดีทีเอ 4 โซเดียม)
Specialty Chemicals (Other special water treatment chemicals)
More information about Water Treatment Chemicals
PKSN RESIN THAILAND
Keywords : Sales Water filter, Sales Ion Exchange Resin, Ion Exchange Resin,
สารกรองน้ำ, Ion Exchange Resin Factory, เรซินแลกเปลี่ยนประจุ ราคาโรงงาน,
ผู้ผลิต ไอออนเอ็กซ์เชนจ์เรซิน, จำหน่าย สารกรองน้ำเรซิน, โรงงาน เรซินกรองน้ำ
  • กระทู้: 3896
Re: Ion Exchange Resin Chemicals, Water Filter Resin Factory, Sales Water Treatment.
« ตอบกลับ #1 เมื่อ: วันที่ 5 พฤษภาคม 2025, 17:55:43 น. »
  • กระทู้: 3896
« ตอบกลับ #2 เมื่อ: วันที่ 6 พฤษภาคม 2025, 19:40:04 น. »
  • กระทู้: 3896
« ตอบกลับ #3 เมื่อ: วันที่ 8 พฤษภาคม 2025, 21:00:17 น. »
  • กระทู้: 3896
« ตอบกลับ #4 เมื่อ: วันที่ 10 พฤษภาคม 2025, 19:53:31 น. »
  • กระทู้: 3896
« ตอบกลับ #5 เมื่อ: วันที่ 11 พฤษภาคม 2025, 18:33:52 น. »
  • กระทู้: 3896
« ตอบกลับ #6 เมื่อ: วันที่ 13 พฤษภาคม 2025, 20:46:52 น. »
  • กระทู้: 3896
« ตอบกลับ #7 เมื่อ: วันที่ 14 พฤษภาคม 2025, 22:20:22 น. »
  • กระทู้: 3896
« ตอบกลับ #8 เมื่อ: วันที่ 15 พฤษภาคม 2025, 21:00:05 น. »
  • กระทู้: 3896
« ตอบกลับ #9 เมื่อ: วันที่ 16 พฤษภาคม 2025, 17:50:48 น. »
  • กระทู้: 3896
« ตอบกลับ #10 เมื่อ: วันที่ 17 พฤษภาคม 2025, 20:41:11 น. »
  • กระทู้: 3896
« ตอบกลับ #11 เมื่อ: วันที่ 21 พฤษภาคม 2025, 20:10:29 น. »
  • กระทู้: 3896
« ตอบกลับ #12 เมื่อ: วันที่ 25 พฤษภาคม 2025, 21:10:05 น. »
  • กระทู้: 3896
« ตอบกลับ #13 เมื่อ: วันที่ 26 พฤษภาคม 2025, 20:03:56 น. »
  • กระทู้: 3896
« ตอบกลับ #14 เมื่อ: วันที่ 27 พฤษภาคม 2025, 18:27:56 น. »
